Topic: My DDJ RR/SR2 doesn't full kill eq
MY DDJ RZ/SZ will full kill an eq when dialed to zero on the eq but my RR and SR2 will not. I was playing a bar last night and literally had the high/mid/low at full kill and the song was playing right along as if nothing happened.
geposted Fri 11 Aug 23 @ 5:11 pm
Using Stems or Frequency Equalizer ?
The DDJ-RR is having its own Hardware EQ (and Mixer) though, so it should apply its own. Not sure if it has any option to change to full Kill
geposted Fri 11 Aug 23 @ 5:43 pm
No stems, just running 32bit. I had fullkill enabled in vdj settings. I dont know of another settings option.
geposted Fri 11 Aug 23 @ 9:23 pm
I think Rekordbox has an "isolator" option that does kill each eq band.
geposted Fri 11 Aug 23 @ 9:28 pm
