what I'm trying to do it set a color rule that is the song exist in a certain playlist it changes color, is this possible?
lets say it the song is in the sidelist or automix list it changes to light blue?
geposted Sun 03 Sep 23 @ 4:06 am
Not possible at this moment.
Basically you can't tell by any means if a song is inside a particular playlist or not, yet alone use that to create a color filter.
The only thing you can do is to use search_playlists action, that will bring up a pop-up window that will list all playlists and virtual folders that a track is listed.
geposted Mon 04 Sep 23 @ 10:57 am
