Hi everyone, it's my first post here so apologies if this has been covered before.
I DJ using a Laptop but use my desktop PC mainly for setting up playlists in Tidal.
The Tidal music beat grids are never perfect, so I manually use the BPM Editor to drag the grids to the beats properly within Virtual DJ on my desktop pc.
As the music is streaming into Virtual DJ from Tidal, there are no music files to copy across from my desktop PC to my DJing laptop for performing.
I'm guessing non-streaming music files would contain beatgrid data and you could just copy across the music folder to a different pc.
Is there a file or folder that I need to copy from my desktop PC to my DJing laptop, that will have all of the saved beatgrid information for Tidal streaming tracks?
geposted Sun 03 Sep 23 @ 10:06 am
database.xml
Click the cog in the bottom corner to locate your home folder.
![](/img/389335/58168/Capture.jpg)
geposted Sun 03 Sep 23 @ 10:14 am
Awesome thanks! I will have a look when I'm back home!
geposted Sun 03 Sep 23 @ 10:38 am
