Topic: rememberRecurse ?
What does the rememberRecurse function do in the options ?
Can someone explain this?
geposted Fri 15 Sep 23 @ 9:15 am
recurse a folder = show the entire contents of a folder [all sub folder contents] not just the files on that level
geposted Fri 15 Sep 23 @ 10:05 am
And "remember" then simply means, that VDJ stores it, so you don't need to do it each time you open VDJ
geposted Fri 15 Sep 23 @ 10:34 am
@Klaus and locodog thanks!
geposted Fri 15 Sep 23 @ 3:47 pm
DJMBR01PRO InfinityMember since 2015
You should create a script/shortcut to add "Thank You Klaus" to your post...it is a common need!
geposted Fri 15 Sep 23 @ 5:30 pm
