My tracks are intermittently skipping/glitching every track does this
geposted Sat 23 Sep 23 @ 6:05 pm
geposted Sat 23 Sep 23 @ 6:23 pm
You've not provided enough information. Please tell us:
Are you using Mac or PC? System spec?
Which operating system is the computer running?
Which version of VirtualDJ are you using (including build number)?
Details of any external equipment - audio interface, controller etc. Make and model.
Location of the files you're playing - internal drive, external drive, streamed?
Format and resolution of files - audio or video? MP3? WAV? Something else? Sample rate? Bit depth?
Which audio driver you're using (if any) and details of audio config, including buffer size.
geposted Sun 24 Sep 23 @ 9:18 am
