hi I m using Mac book pro I try to install the virtual dj 2023 its install but I cannot login in the software which shows me the error of internet connection. please help me with its issue.
geposted Sun 08 Oct 23 @ 12:42 pm
cant log in my controler without buying license ...last time and normaly i can use a controler for home users... why not yet... is it a internet connect. problem ??
geposted Sun 08 Oct 23 @ 1:58 pm
Support staff wrote :
geposted Sun 08 Oct 23 @ 2:04 pm
ok ok... i see u understand and maybe find the problem .... after using ure link , my programm getz now to log in on the site and conect the prog with the internet ... but i got the same problem as well in the end because the host-file from ure link only incl a older pro version and so it ends every 10 minutes... BUT BEFORE i got the infinity 8.7 version ...full conecte.... why not yet ..
geposted Tue 10 Oct 23 @ 11:27 pm
You have to buy the software from here, https://www.virtualdj.com/buy/index.html
Buying it from ANYWHERE else isn't a legitimate copy.
geposted Wed 11 Oct 23 @ 12:31 am
no.. the guy who give it to me as a present buy it all together ...controler and licenses but he got nothing about or from it now .... and i cant use any version of my cause u got blocked them all ...why... do u cant see in my present log in´s which licenses i got and recreate them ... please ..
geposted Sun 15 Oct 23 @ 3:18 pm
http://www.virtualdj.com/help/
Click "Contact Support"
then
Click "Contact Us"
This isn't an issue that can be resolved on the forum.
then
Click "Contact Us"
geposted Sun 15 Oct 23 @ 4:11 pm
virtual dj 2023 pc64 build 7482.1932 - not logged in
geposted Wed 24 Jul 24 @ 10:25 pm
