Topic: Automix won't play more than 2 songs
Hello all!
I am relatively new to the program so apologies if this topic is a known issue. I tried looking for something similar but couldn't find a solution to the problem.
So, I have enough songs loaded in Automix and when I try to start it, it just plays the first song on deck 1 and then stops right after it (without loading or playing the next one). The icon for automix is not lit and when you select the dropdown menu there is no tick next to "Start automix".
I played with the settings and the only way I managed to actually blend 2 songs (not more) was to activate the Automix option on 2 decks. Then the icon is active and I can see the tick, BUT it won't play more than 2 songs...
So no matter what I do, the Automix doesn't run as it should for me. Any ideas?
geposted Mon 09 Oct 23 @ 9:06 am
Are you using Tidal streaming?
geposted Mon 09 Oct 23 @ 9:37 am
geposted Mon 09 Oct 23 @ 9:45 am
I see. Yes, that solves the issue then.
Thank you much
geposted Mon 09 Oct 23 @ 12:09 pm
