So guys, for a Mac, the included fx's in VDJ doesn't sound nearly as good as VST plugin effects so I am wondering if there might be any good options of any sort for this please?
geposted Wed 11 Oct 23 @ 5:52 pm
not wanting to hijack but am also looking for audio unit for macs that just does volume
geposted Wed 11 Oct 23 @ 5:58 pm
np. Wait a minute, my research is showing that VST's does work with VDJ on a Mac just that the VST need to be 64 bit:
https://www.virtualdj.com/wiki/howtousevsteffects.html#:~:text=To%20use%20a%20VST%20effect,VirtualDJ%2FPlugins64%2FSoundEffects%2F.
geposted Wed 11 Oct 23 @ 7:34 pm
free reverb https://www.voxengo.com/product/oldskoolverb/
free delay https://www.voxengo.com/product/sounddelay/
geposted Wed 11 Oct 23 @ 7:51 pm
Thanks, I'm trying but not understanding how to get this to work. The user file shows the process is to "drag and drop the 'component for vat' file from it into the plugin folder' but as this screenshot shows when I open the downloaded dmg file, I am not noticing any file titled 'component'?
https://i.postimg.cc/sxGycfQy/IMG-4483.jpg
geposted Thu 12 Oct 23 @ 1:34 pm
The .vst3 is probably the one you want to copy
geposted Thu 12 Oct 23 @ 2:01 pm
YES, THAT DID IT! Thank you very much!
geposted Thu 12 Oct 23 @ 3:11 pm
