I am trying to use VDJ with my new tech - a 13inch touchscreen. I am unable to access the context menus, or any other right click access for that matter. I'm using win11 and all settings for tablet/touchscreen are correct; it works as expected within windows.
Is this a limitation of VDJ or am I missing a buried setting somewhere? TIA
geposted Sat 28 Oct 23 @ 4:08 pm
Did you try press and hold?
geposted Sat 28 Oct 23 @ 4:13 pm
yep, it works in windows but not in VDJ.. eg try to press and hold for video screen context menu
geposted Sat 28 Oct 23 @ 4:24 pm
or the browser... can't right click on files
geposted Sat 28 Oct 23 @ 4:26 pm
Do you have touchScreenMode enabled inside VDJ settings?
geposted Sat 28 Oct 23 @ 4:42 pm
Same response either way, enabled or not..
Do you have it working on a touchscreen?
geposted Sat 28 Oct 23 @ 4:51 pm
My gig machine is touchscreen, will check in about an hour when I get to the venue.
geposted Sat 28 Oct 23 @ 5:14 pm
Holding on my touchscreen brings up the right click menu
![](/img/392784/15041/20231028_200947.jpg)
geposted Sat 28 Oct 23 @ 7:11 pm
geposted Sun 29 Oct 23 @ 7:04 pm
Thank you.... its all coming back to me now!
Age gets us all.... lol
geposted Mon 30 Oct 23 @ 12:32 am
¯\_(ツ)_/¯
geposted Tue 31 Oct 23 @ 7:59 pm
I think at least in the default skin the video output menu is pretty much the only thing that you'd need the right-click menu for right?
geposted Wed 01 Nov 23 @ 4:58 am
I would also need it with pad functionality, eg deleting hotcues, track options in browser etc. As I'm coding a touch optimized skin I will put a shift button in the topbar and use that instead of right-click when I can
geposted Wed 01 Nov 23 @ 9:06 am
With pads there's not really any other choice than a shift button, since most of the regular actions require instant interaction. (You don't want your hot cue to delay triggering to be sure you didn't mean to do a long press)
geposted Wed 01 Nov 23 @ 9:38 am
