Topic: How to split effect decks???
So.....my problem is when I want to for example set CTRL+NUM9 effect_slider 1 1 +3% this moves only left side and I cant figure it out how to set that so it moves right side..... If you understand.
geposted Thu 02 Nov 23 @ 6:15 pm
use
leftdeck
rightdeck
or
deck left
deck right
geposted Thu 02 Nov 23 @ 6:55 pm
One way is to have a single button without deck specific and switch the selected Deck by using the .. deck active select action mapped to some key
Or, have 2 buttons (one for each deck) by using deck left or deck right in front of the action.
So, deck left effect_slider 1 1 +3% and deck right effect_slider 1 1 +3%
geposted Thu 02 Nov 23 @ 7:01 pm
