Topic: Sampler bank polyphoic VS mono?
Encountered an odd thing that probably a simple fix.
I created 3x sampler banks with some drum loops. Two of the three trigger monophonically (only one sample loops at a time. Hit a different pad and first loop stops).
However, the third bank plays polyphonically (the loops keep playing even when new pads are launched).
I see trigger settings but they don't really cover this as far as I can see.
How do I set a bank's polyphony? (I want the mono way)
geposted Fri 03 Nov 23 @ 6:17 am
SOLVED: in the sample editor, set the samples into the same group. They will then mute eachother inthe order launched.
geposted Fri 03 Nov 23 @ 6:20 am
