Topic: Jog wheel bend.
What’s the best setting for jog wheel bend? I’m mostly having the same song on each deck. So if I wanna blend them together and give them that cool flanger sound. what’s the best number?
geposted Sat 04 Nov 23 @ 6:57 pm
I mix mostly r&b and hip hop if that helps.
geposted Sat 04 Nov 23 @ 9:10 pm
It's subjective, try stuff till you find a value you like.
geposted Sat 04 Nov 23 @ 11:39 pm
Ok thanks for the information.
geposted Tue 07 Nov 23 @ 2:31 am
