Topic: Microphones...
Hi folks - Are mics enumerated in VDJ - - can i eb
enable/disable mic 2 in script for instance? - Assuming I can - how would I address mic2 as opposed to the default 'mic' ?
TIA
geposted Sat 11 Nov 23 @ 12:01 pm
As far as i know, you can have 2 Microphone inputs in Audio setup, but both are probably enabled/disabled by the mic action (no mic2 action AFAIK). You have mic_volume and mic2_volume though you could set to 0/100 if u want to turn off/on.
geposted Sat 11 Nov 23 @ 3:25 pm
oh ...shame - thanks :
geposted Sat 11 Nov 23 @ 4:25 pm
Tear Em 'UpPRO InfinitySenior ModeratorMember since 2006
Another option is to pick up a USB mixing board, like the Xenyx series from Behringer, and set is at the mic source. You can run as many mics as the mixer has inputs.
geposted Mon 13 Nov 23 @ 2:28 pm
