DJ VinylTouch wrote :
This is very great news indeed 🍺 - kudos to the team for getting this done so quickly (another reason to give thanks this weekend).
However, I've noticed one major issue and two minor issues specific to the Phase HID usage (at least on my end) when using b7816 (M1 MacBook Pro, 2020, 16 GB RAM):
- (Major Issue) There is serious drift in the tracking of remotes when I use them on my turntables (Reloop RP7000 MK2s). The pitch readout on the skin is saying they are matched, and they may start matched, but the eventually go out of time very quickly, especially if I do any manipulations of the record. It is drift because:
- I've tried it with the same track, and the pitch reset on for each deck, using the remotes (which should make both tables spin at the original BPM of the song)
- I did the same thing with regular VirtualDJ vinyl records and they are much better matched (respecting the pitch readout on the table to within 1 decimal place) - (Minor Issue) PHASE-LedMode does not have an option to respect the remote LED color that is chosen in the Phase MWM Manager itself - it always overrides with the default colours listed in the hardware page
- (Minor Issue) There should still be an option to still use the regular RCA mode with Phase
It was unclear to me from modifications to the manual, if that was still possible, and some people do prefer the original DVS Timecode signal reproduction behaviour.
I just came from Serato and just got VDJ installed today, and I agree there is some serious drift with HID mode. I also tested this against the ignore option for Phase in VDJ and everything was fine. Not only is there a drift. There is a rather large delay on how long it takes the pitch to react. Don't work too hard on it though, I might end up going back to my Ortofons. This is setup using the default options in Phase Manager (which is Serato)
geposted Sat 23 Dec 23 @ 7:44 am
FYI: Phase is planning to finally re-release the new update and firmware (version 2.4.2/firmware 8) next week according to their official Facebook Page.
geposted Sun 24 Dec 23 @ 10:56 pm
Looks like Phase still hasnt released their new version so this wont work as HID yet.
geposted Thu 15 Feb 24 @ 1:35 pm
Ok so it’s been about a week since I’ve used Phase.
Connected my DJM 450 and set the utility to LINE.
Open the Phase manager and calibrate the sticks.
Open VDJ and set my timecodes to PHASE.
As soon as I load up a track and press play on my turntable the it sounds like it’s playing double the speed!! I can not for the life of me figure it??
Any suggestions??
Any suggestions??
geposted Sun 18 Feb 24 @ 6:16 am
What is the firmware version of your Phase ?
If HID is available, then the Phase needs to be ignored from Controllers
geposted Sun 18 Feb 24 @ 7:37 pm
Mine are v7
Here’s a video so you can see everything I’m doing.
https://youtu.be/T4gb0D8ZTfQ?si=sapNocFSbh_0OLRT
geposted Sun 18 Feb 24 @ 9:46 pm
