@VISIONZ5
Got your video, thanks.
1. when you use the Phase in HID, the play/stop/pause actions do not work. So probably nothing to do with the keyboard Mapping/shortcuts. You could also try to pause/play from the Skin buttons too.
This is the way we have implemented the Phase in HID, it only listens to the Remote rotation and not the internal Play buttons.
Not sure how "practical" it is to pause/stop the Deck while the TT is still spinning. In what cases you want to do this ?
2. You pressed some buttons on your Z2 mixer for DVS (?). What is the action of this button and what exactly do you want to do when using this ?
Keep in mind that once you choose the DVS mode from the Phase settings, you dont actually need to do anything else, other than having your timecode inputs configured in your Audio Setup.
Tip : If you guys need some shortcut to switch between the Phase modes, use the action setting 'settingName' 'value'
E.g. the action ..
setting 'PHASE-HIDmodeLeft' 'DVS' & setting 'PHASE-HIDmoderight' 'DVS' will switch both Remotes to DVS
setting 'PHASE-HIDmodeLeft' 'HID' & setting 'PHASE-HIDmoderight' 'HID' will switch both Remotes to HID
setting 'PHASE-HIDmodeLeft' 'Disabled' & setting 'PHASE-HIDmoderight' 'Disabled' will disable both Remotes (in case you want the "internal" mode and/or want to put Remotes to base.
E.g. the action ..
geposted Wed 03 Apr 24 @ 2:26 pm
@VISIONZ5 I thought you would want to use the buttons on the Z2 to toggle between the Phase modes, so here are the actions you could use...
TIMECODE_ON:
LED_TIMECODE_ORANGE:
LED_TIMECODE_GREEN:
Untested - don't have the Z2
With the above actions, the buttons on your Z2 should now toggle between HID (led green) and DVS (led orange).
SHIFT+DVS buttons should "disable" both DVS and HID (leds off), so will offer the "internal" mode
TIMECODE_ON:
shift ? device_side 'left' ? setting 'PHASE-HIDmodeLeft' 'Disabled' : setting 'PHASE-HIDmodeRight' 'Disabled' : device_side 'left' ? setting 'PHASE-HIDmodeLeft' 'HID' ? setting 'PHASE-HIDmodeLeft' 'DVS' : setting 'PHASE-HIDmodeLeft' 'HID' : setting 'PHASE-HIDmodeRight' 'HID' ? setting 'PHASE-HIDmodeRight' 'DVS' : setting 'PHASE-HIDmodeRight' 'HID'
device_side 'left' ? setting 'PHASE-HIDmodeLeft' 'DVS' ? on : off : setting 'PHASE-HIDmodeRight' 'DVS' ? on : off
LED_TIMECODE_GREEN:
device_side 'left' ? setting 'PHASE-HIDmodeLeft' 'HID' ? on : off : setting 'PHASE-HIDmodeRight' 'HID' ? on : off
geposted Wed 03 Apr 24 @ 3:20 pm
@MOYSESSENA, @DJVINYLTOUCH
I'd like to get some video from you guys when you can, showing the issues you have with the HID mode.
geposted Wed 03 Apr 24 @ 3:27 pm
djdad wrote :
What is your setting TimecodePitchSliderIgnoreBend set to ?
If set to Yes (default), i don't get any beatgrid advancing or anything similar when scratching/braking/releasing
moysessena wrote :
The problem remains. When trying to brake the disc, the beat grid advances on its own as if I were pushing the disc. Exactly as described previously.
TimecodePitchSliderIgnoreBend=YES
![](/img/403163/96766/vdj.png)
geposted Wed 03 Apr 24 @ 4:40 pm
https://www.youtube.com/watch?v=l5QnPf64xfI
Note that when braking the disc with your hand, normal pitch bend, the grid moves backwards and then forwards without any interference.
In DVS mode this does not happen. When braking the disc, the grid remains where I finished braking.
geposted Wed 03 Apr 24 @ 4:58 pm
This happened exactly when the first version with HID mode support was released, but it was much more pronounced, then you corrected it and it worked fine until the V9 firmware update.
HID mode on Serato works perfectly as always. No unexpected variations.
geposted Wed 03 Apr 24 @ 5:03 pm
This video pretty much shows the problem...I'll provide a video later on today to support it.
geposted Wed 03 Apr 24 @ 7:23 pm
Here's my video showing the problem (and a comparison to Phase DVS which doesn't have the problem)
geposted Wed 03 Apr 24 @ 8:48 pm
