I need to know in real-time the track loaded per deck.
What is the right way to approach this?
I see that History file only has a song added based on a configuration value of X seconds (45 is default?)
I tried following Developer SDK but it's not clear if I can simply query a web endpoint locally on the machine or if I have to write a plugin that will send this data on track load.
Alternatively the "Remote" function looks like a possibility, but I can't find much information on this either.
Any guidance would be appreciated 🙏🏼
geposted Wed 29 Nov 23 @ 4:20 am
Writing a plugin is an option, but using the Network Control Plugin is probably an easier way to extract the data to your own application:
https://virtualdj.com/wiki/NetworkControlPlugin.html
geposted Wed 29 Nov 23 @ 5:10 am
Thank you Adion
I'm trying to find:
- Number of Decks currently
- For each deck, the current file name, artist, or title
Is this possible with any vdj scripts?
I'm trying to find:
geposted Tue 05 Dec 23 @ 3:39 am
get_decks
get_loaded_song 'FIELD'
geposted Tue 05 Dec 23 @ 4:26 am
