Topic: Can't load iTunes into virtual dj
Several days ago I purchased a new gaming laptop and tried to load my purchased music from iTunes. I went to the iTunes library, export library file.xml, open up virtual dj, went to options and tweaks, I clicked the down arrow to open the file, I clicked on iTunes library.xml. in virtual dj. I clicked on music into the left side panel of virtual dj to open my music but nothing loaded. When the music didn't load, I uninstalled iTunes and re-installed it going through the same steps I just explained and got the same results. Please tell me how to fix this problem.........dj nushuz
geposted Fri 05 Jan 24 @ 12:29 am
VDJ does not play DRM files.
It’s been many years since I last used iTunes but from what I recall you do not open the library file in Virtual DJ.
In settings search for iTunes and ensure the location of the file is correct. Then, in the browser, you should see an iTunes folder under Local Music, then Music. The music should be there - provided it is purchased and not DRM-protected. An Apple Music subscription is not purchased music.
