Topic: Drawing & Coding
Hi, I understand in version 8 you can draw decks yourself? Just replace the textures in the folder, but is it possible to add any other effects in pads? Or BrakeStart to increase not to 12s, but to 20 for example?
geposted Sun 07 Jan 24 @ 2:19 am
pads are just like keys you can remap however you want with the pad editor.
brakeStart with the plugin the limit is 12s and that's it, but with a virtualFX you could assign that to rampStartTime, rampStopTime. It would act exactly as brakeStart but under the hood it's manipulating settings.
geposted Sun 07 Jan 24 @ 2:32 am
Good answer, thank you. I'll get on it
geposted Sun 07 Jan 24 @ 2:34 am
geposted Sun 07 Jan 24 @ 2:40 am
No need to stress, I'll read in your discord server info and if anything I'll ask there ;)
geposted Sun 07 Jan 24 @ 2:45 am
already done, see thread
geposted Sun 07 Jan 24 @ 4:11 am
