Hello everyone. I'm a bit new to this and I can't find a way to do it.
I usually use Virtual DJ with the crossfader deactivated. What I want is to make a script that allows me to activate smart_fade and the crossfader at the same time and when I execute it again, disable smart_fader and turn the crossfader back as it was.
I'm trying this:
smart_fader ? ( crossfader_disable `get_var '$CF'` & smart_fader off ) : ( set '$CF' `crossfader_disable` & crossfader_disable off & smart_fader on )
but doesn't work as I need. I think the problem is probably in "crossfader_disable `get_var '$CF'`".
My knowledge is limited.
Anybody can help me?
I'm trying this:
geposted Mon 08 Jan 24 @ 11:24 am
smart_fader ? crossfader_disable on & smart_fader off : crossfader_disable off & smart_fader on
no need for a var
no need for a var
geposted Mon 08 Jan 24 @ 7:05 pm
Hello locodog and thanks for your suggestion. The problem with your code is that when deactivating smart_fader the crossfader is always disabled. What I want is to return the crossfader to the last state used before activating smart_fader.
This is my new code and it seems to work fine:
smart_fader ?
on & deck all pitch_zero & smart_fader off & var "$CFD" ? crossfader_disable on : crossfader_disable off :
smart_fader on & crossfader_disable ? set "$CFD" on & crossfader_disable off : set "$CFD" off & crossfader_disable off
smart_fader ?
geposted Tue 09 Jan 24 @ 9:22 am
