Topic: map button to skin 2 / 4 deck visible
Hi, I'd like to map a button to toggle between 2 and 4 decks visible in the performance layout of the stock skin. Is this possible?
geposted Mon 08 Jan 24 @ 3:33 pm
Yes, it's basically a parameter, and then reloading the skin
If you already have performance layout selected, you can map a 4 deck toggle using:
toggle '@$4decks' & load_skin
geposted Mon 08 Jan 24 @ 5:08 pm
That's great, thanks :)
geposted Tue 09 Jan 24 @ 3:36 pm
