I just bought a new gaming laptop so I can do stems with my new Rane Four. Ever since I did that I cannot stream to Mixcloud Live and record at the same time. If I start them simultaneously, the stream won't stream. If I start the stream first, it will stream until I hit record and the stream stops or is corrupted some how and stops. I never had this issue on the last laptop and the last deck. Any thoughts?
geposted Sat 13 Jan 24 @ 3:22 am
The official support won't help. They're like - we can't reproduce it so GOODBYE. WTF? I realize this is not something many people do but wow.
geposted Mon 15 Jan 24 @ 11:40 pm
Now I've got the same issue after reinstalling V-Dj
geposted Wed 14 Aug 24 @ 5:02 pm
Never reinstall - that never makes a difference
You are simply replacing the VDJ executable files with the exact same executable file, and you risk loosing your database, history, configurations and so on if you are not really careful
geposted Thu 15 Aug 24 @ 1:40 am
Download black hole and set that as another master out within VDJ, then open Audicity and record you set while streaming.
And if you’re using something like Restream it’ll automatically record the set for you.
But I’m sure VDJ will stream and record at the same time 🤔
geposted Thu 15 Aug 24 @ 7:27 pm
I've just tried this 2 minutes ago (M1 MacBook Pro, Sonoma 14.4, VirtualDJ 2024-m b8280) - started rtmp stream to Restream, no destinations activated + start recording audio as flac, and it worked fine (both Restream output and recording output). I also regularly broadcast to radio.co via shoutcast and record to flac at the same time with no issues.
Not sure if it could be a Windows or Mixcloud specific issue however...and I have no Windows machine to test with.
geposted Thu 15 Aug 24 @ 8:23 pm
