Topic: Modifying "Auto Sync on Play" by script?
Hello,
I can change the auto_match_bpm=0/1 by script easly.
But how to achieve the same for "Auto Sync On Play"?
I mean, there is only auto_sync_options/auto_sync_settings, but how can I exactly modify the sync on play behaviour?
Thanks
geposted Tue 23 Jan 24 @ 10:19 pm
look up
smart_
in the mapping window.
geposted Tue 23 Jan 24 @ 11:00 pm
No that's not what I'm looking for!
I'm searching the "Auto Match / Auto Sync" settings from the popup menue if you hit the gear beside the loop buttons.
geposted Wed 24 Jan 24 @ 12:08 am
that is what you're looking for.
geposted Wed 24 Jan 24 @ 9:02 am
My bad! The script value I was looking for is indeed: smart_play
geposted Wed 24 Jan 24 @ 9:28 am
