Topic: HELP :-(
hello Team!
I have a Pioneer DDJ-RR with VDJ8.
I have a mapping problem on:
my jogs which do not allow me to set my tracks,
make a bacspin
can anyone give me the code to correctly map my jogs?
Thanks a lot !
geposted Sat 03 Feb 24 @ 2:00 pm
You need at least build 3291. What do you have installed?
geposted Sat 03 Feb 24 @ 3:46 pm
Hello and thank you for helping me.
I don't understand which version you are talking about :-(
I am in V2023 b7482 on virtual dj.
Where can I find the reference you mentioned?
Cdt
geposted Sat 03 Feb 24 @ 4:39 pm
geposted Sat 03 Feb 24 @ 4:47 pm
Thanks !
I want to try ;-)
geposted Sat 03 Feb 24 @ 5:51 pm
I don't know how to lower my jingles sound effect down
geposted Mon 05 Feb 24 @ 10:36 am
#Adion
J’ai regardé la notice que tu m’as passé et j’ai contrôlé si mon contrôleur est en HID.
Par contre quand je regarde la liste des contrôleurs proposés, je n’ai qu’un seul pionnier DDJ-RR de proposé et non deux comme expliqué dans la notice,
Et je pense que c’est de la que viennent les problèmes car je ne semble pas avoir la fonction rekordbox 😢
Merci
geposted Fri 16 Feb 24 @ 12:54 pm
