Topic: Custom Stems / EQ mapping
After playing with the STEMS feature now since it launched right up till the very latest version (which is awesome by the way) I would very much like to try a custom mapping but I'm not entirely sure if this is possible or not.
What I would like to do is have :
HIGH = VOCAL
MID = INSTRUMENTS
BASS = NORMAL BASS CUT/AMP
I've settled into playing in a way in which vocals / instruments seem to be the two that need isolating the most and bass behaving normally is fine.
The way I have this setup right now is on a four channel mixer using the EZ Remix feature... so I'm using the HIGH / MID from the outer decks and the LOW on the inner decks... I would very much like to be able to map this to just the channels on the inner decks... This would also allow me to use a 2 channel mixer.
Any clues on how to do this? I did just look at remapping and it appears (at first glance) that HIGH/MID/LOW just get assigned to whatever STEMS mode is set... whereas I would really like to have more control over which knob does which.
Really hope this is possible and somebody can point me in the right direction!
Thanks in advance.
geposted Sat 03 Feb 24 @ 3:42 pm
stem vocal
stem instru
eq_low_freq
geposted Sat 03 Feb 24 @ 4:23 pm
