Topic: Deck 1 Audio Feedback/Glitch Issues
Hey all.
I currently have this issue that only affects my Deck 1. Sometimes when I go to play a song, it has this horrible sounding effect to it. I'm not sure if it's distortion/feedback etc, it's just higher pitched and like nails on a chalkboard.
Sometimes it happens when I play a track outright, or sometimes it happens when I use the pitch slider to change the BPM. It isn't anything to do with my files because it can happen at any time, with any track or video.
The part I find strange is that it's only on one deck, not the other.
I uploaded an unlisted video to show you all what I mean. You'll find the track is fine at first, then when I use the slider, it royally messes up. However note that sometimes it can sound like that sometimes when I simply play a file. You can find it here: https://youtu.be/Yg0bxqc5744
Hopefully someone can help - I regularly livestream and also have been asked to do an IRL gig and having this issue isn't the best.
geposted Mon 05 Feb 24 @ 12:36 pm
try updating drivers especially audio
geposted Thu 15 Feb 24 @ 11:07 pm
