Hi
I have files in my iTunes library list with the red cross. I am unable to delete them. I have done the following:
1. File operations>Delete - Nothing happens
2. File operations>Show in finder - Nothing happens
3. Checked the iTunes root folder on my mac - no such folder exists
4. There are no virtual folders, so no files there
5. I saw that you can go to Browser options>Database>Remove etc... on a thread but I think it's an old thread as I am unable to see where to do this in the setting of version 781.2034
6. This is a clean install on VDJ today.
To be honest I was having the same problem in Serato earlier today and thought ok, that's me done with it, I'm going back to VDJ (Only went to Serato as I got the Pioneer DDJ-SR2 controiller a few months back) and tbh I hate Serato compared to VDJ, I just need to get rid of these tracks.
Any help appreciated - thanks in advance.
Ricardo
Ricardo
geposted Fri 09 Feb 24 @ 2:29 pm
I've found the browse>database>remove missing files option but they are still there :-(
geposted Fri 09 Feb 24 @ 2:35 pm
then your itunes list is still listing those tracks, maybe you've deleted them outside itunes and not updated the itunes listing.
geposted Fri 09 Feb 24 @ 2:40 pm
I've looked in iTunes and can't see them, i'll check again....thanks.
geposted Fri 09 Feb 24 @ 2:44 pm
Eventually found them, removed them and all is good - thanks all.
geposted Fri 09 Feb 24 @ 3:08 pm
Also check your playlists
geposted Fri 09 Feb 24 @ 3:57 pm
