I have a Hercules Inpulse 500 which has 4 fx buttons (for mixer effects), and I find that it's not quite enough. I was wondering if it would be possible for VDJ to default to the filter effect when none of the effects are selected on the controller. That would give a total of 5 mapped effects. Is this do-able?
geposted Sun 18 Feb 24 @ 3:32 pm
I'd like to set mine up like this too! I managed to figure out how map the other buttons, so may have a go at this (unless someone can tell me of course 😆)
geposted Tue 20 Feb 24 @ 8:36 pm
you could have 8 or more if you wanted. It's pretty easy.
you've got 4 mixerfx buttons mapped like this
and their LEDs mapped like this
for 8 possibilities you could remap like this [just example 1 case]
and LED like this
if it wasn't on filter then first press brings it on to filter, second press brings it to cut
if was on filter already it press just goes to cut.
original type blinks at original speed, second type blinks fast.
deck all filter_activate 'Filter'
deck all filter_activate 'Echo'
deck all filter_activate 'Pitch'
deck all filter_activate 'Noise'
deck all filter_activate 'Filter' ? blink : on
deck all filter_activate 'echo' ? blink : on
deck all filter_activate 'pitch' ? blink : on
deck all filter_activate 'noise' ? blink : on
deck all filter_activate 'Filter' ? deck all filter_activate 'cut' : deck all filter_activate 'Filter'
and LED like this
deck all filter_activate 'Filter' ? blink : deck all filter_activate 'cut' ? blink 250ms : on
geposted Tue 20 Feb 24 @ 8:52 pm
Thanks locodog, I've been reading through your script school thread and playing about trying to learn more! Excellent work, cheers!
On the inpulse 500 there are the 4 FX buttons and a knob to adjust wet/dry... If none of the FX buttons are activated that knob does nothing... I think the OP (but definitely me!) would like that permanently mapped to filter when no fx button is active. Then reassign the redundant filter button to another effect.
Reckon that's possible mate?
geposted Wed 21 Feb 24 @ 7:41 am
I thought I'd explained enough
becomes
take the time to actually understand the logic and the script that makes it happen.
becomes
deck all filter_activate 'Echo' ? deck all filter_activate 'filter' : deck all filter_activate 'Echo'
geposted Wed 21 Feb 24 @ 12:24 pm
This is super clever! Thank you, I'll give it a try.
geposted Sun 05 May 24 @ 3:03 pm
