Would it be possible to get an option to have autoCue trigger before keepPlayStatusOnLoadsong?
Right now it seems that the song will always start from the beginning when keepPlayStatusOnLoadsong is enabled/triggered - so you can't use the feature to have the loaded song start at first cue point even when autoCue is set to cue
A quick workaround is to disable keepPlayStatusOnLoadsong, and add PLAY to onSongLoad (on for instance the keyboard mapping), but then it doesn't respect the current status on the deck - it simply always plays on song load
geposted Wed 21 Feb 24 @ 1:44 pm
maybe leave settings as is and then map
OSL: ( play ? goto_cue : )
geposted Wed 21 Feb 24 @ 2:00 pm
Actually a bug imo, so will be fixed indeed.
(If you do want it to start from the beginning you can just disable autoCue instead)
geposted Wed 21 Feb 24 @ 2:05 pm
