Topic: HELP!!!!! please
davew45PRO SubscriberMember since 2024
Hiya, I currently broadcast live on live365 using virtual on my laptop. I have that go into a Hercules starlight and that goes into a weymic 7 channel audio mixer. However when i broadcast live everyone can hear the music on channel one but cant hear my jingles on channel 3 and my xlr microphone on channel 5 despite the sound being right up any advice please
geposted Fri 23 Feb 24 @ 3:34 pm
Assuming you're broadcasting directly from VirtualDJ, that audio signal is coming from the software mixer (controlled by the Hercules). If you're sending the output of the Hercules to a second mixer, the listeners won't hear the output of that second mixer.
geposted Fri 23 Feb 24 @ 3:55 pm
so how do i get the 2nd audio mixer to connect to virtual dj then please
geposted Fri 23 Feb 24 @ 4:19 pm
You would need to connect an output of your mixer to a line input on your PC/laptop.
Then in VirtualDJ sound setup you would need to add a recording source, and specify your PC/laptop soundcard as the source device.
geposted Sat 24 Feb 24 @ 12:04 am
Of course, do not feed the output of the Hercules (master signal) into the Weymic and then feed the Weymic output back into VirtualDJ.
geposted Sat 24 Feb 24 @ 9:23 am
