I m tryin to use a filter folder to show energy so I renamed one of the user fields to show this information. When I setup the filter it does not seem to work. In the picture I want to see only Energy above 65 but as you can see it shows all the songs. This filter works the way I want when I use the track field but not the user fields. Could this be a glitch?
Thanks in advance
Thanks in advance
geposted Sat 02 Mar 24 @ 6:21 pm
It's not a numerical field, it's a string of characters, therefore mathematical operations like ">" won't work
track number would be a better tag to co-opt as energy
geposted Sat 02 Mar 24 @ 6:33 pm
Oh ok. I noticed the greater and less then are not in every field so I thought since they were in this one they would work. Thanks
By chance which fields besides track are mathmetical fields?
geposted Sat 02 Mar 24 @ 6:38 pm
edited above, but track number works.
geposted Sat 02 Mar 24 @ 6:43 pm
@ djjoe21 what skin are you using, which has a prep mode ?
looks interesting ..
geposted Sun 03 Mar 24 @ 5:33 am
looks like phantoms gks skin
geposted Sun 03 Mar 24 @ 2:41 pm
It's PhantomDJ I only use it for track prep. I like all the easy access custom buttons. It's a little older but haven't found or really needed anything better.
geposted Sun 03 Mar 24 @ 3:24 pm
Thank you .. will have to check out the skin !
geposted Mon 04 Mar 24 @ 12:19 pm
