Hello,
I am using an oldschool midi controller (Behringer BCR2000 - but should not really matter) as a secondary controller. I want to map buttons to activate effects etc, but of course those buttons do not know about decks. How do I for instance activate my backspin FX on deck 2? Probably it's simple.
Another related question: I want to map a rotary button to tune the pitch down (and I mean, pitch as in frequency, not BPM, i.e. pitch-shift). How do I do that?
geposted Mon 04 Mar 24 @ 9:12 am
If you look at the VDJScript page in the wiki, one of the first things mentioned is assigning script to act on a particular deck.
Sepatro wrote :
tune the pitch down
That would be the key. Again, in the wiki - key or key_smooth
geposted Mon 04 Mar 24 @ 9:20 am
Probably :)
geposted Mon 04 Mar 24 @ 9:26 am
Sepatro wrote :
tune the pitch down
That would be the key. Again, in the wiki - key or key_smooth[/quote]
Thanks - key_smooth is what I need. I could also use the Pitch Shift FX, but I prefer changing the key.
geposted Mon 04 Mar 24 @ 9:27 am
