Hi,
I've used VDJs CDJ export feature to export my playlists, but my Denon prime doesn't recognize the database. It doesn't show the playlists, won't let me search files, and won't even load the track when I select it manually from the content folder.
I know CDJ export creates a recordbox database for Pioneer equipment, but Denon / Engine can normally read recordbox databases without a problem.
geposted Tue 05 Mar 24 @ 3:25 pm
Update: Recordbox (the desktop software) itself doesn't seem to recognize the database either, so I must be doing something wrong...
geposted Wed 06 Mar 24 @ 7:29 pm
Update: seems the SD card was the problem. Now I've formatted it to ExFat and now it works fine on Denon Prime :-)
geposted Sun 19 May 24 @ 8:52 am
