Hello,
I am mapping my rotary controllers of my BCR2000 to change the keys of the 4 different decks. I use 4 rotary encoders next to each other, one for each deck. Deck 1 and 2 work just fine, however deck 3 and 4 have a strange behaviour. Could this be because, for one reason or another, VDJ interprets CC controllers 97 and 98 (correctly) as sliders, but 99 and 100 as "encoders"? See image.
geposted Sun 10 Mar 24 @ 3:39 pm
I now notice that I can choose between SLIDER or ENCODER.
The exact syntax however it not clear to me ...
geposted Sun 10 Mar 24 @ 4:00 pm
for encoder type use
key
for slider type use
key_smooth
encoder will give whole number note changes,
slider will give +/- 6.0 key differences including in between key values like +4.2
key
for slider type use
key_smooth
geposted Sun 10 Mar 24 @ 4:36 pm
thanks - I used slider and used a multiplyer
geposted Sun 10 Mar 24 @ 5:07 pm
