Topic: LEFT Justify the BPM?
Hi all. Having a TON of trouble adjusting from my previous software. It's mainly because my old one had the bpm field left justified so there was a gap there after it. As I'm looking now, the numbers just run one into each other. I can't stand it. Is there an easy fix?
geposted Fri 15 Mar 24 @ 3:13 am
Which numbers are they running into? The length is also right justified, so that shouldn't be an issue.
geposted Fri 15 Mar 24 @ 3:16 am
