Tested on RTX 3050 Laptop 4Gb VRam
1° Open Virtual Dj options check option DO NOT USE GPU close virtual dj
2° Open Virtual dj UNCHECK DO NOT USE GPU and SELECT THE NVIDIA GRAPHICS CARD and close virtual dj
3° Open virtual dj and Ready Working Stems 2.0 Nvidia RTX 3050 4gb
credits to Dj Paul gave that solution in the Spanish forum
Be careful, it's a bug, you should fix it.
geposted Sat 16 Mar 24 @ 10:26 am
