if you have filters added under virtual folders, they aren't showing any more on the new update.
when you click on the plus sign to show them, instead the plus sign just vanishes. If you add a new filter within a virtual folder it will let you make one, but it won't find anything in that virtual folder. and will also dissapear afterwards.
if you close all filters and then open the menu up again, it will show all the pluses again. but they still don't work.
geposted Thu 21 Mar 24 @ 7:53 am
I had reported this as well, so they know about it. For now, you need to close VirtualDJ, go to the VirtualDJ folder, outside of Virtual itself and manually recursively copy the folder structure you see under Folders/Filters into the MyLists folder, then restart VirtualDJ - the filters will show up under MyLists.
geposted Thu 21 Mar 24 @ 2:54 pm
