Anyone else have this issue? I've had it for years....VDJ randomly puts a "+" sign next to virtual folders, even though there are no sub-folders in said folder. It's random, doesn't do it everytime, and when I click on the plus sign is just goes away. Can I live with, yes. Is it on the annoying side, yes.
geposted Wed 27 Mar 24 @ 12:59 pm
Which build are you using ?
The + sign appears because there are empty "folder.subfolder" files on your parent folder.
This has been fixed on latest EA version.
So, if you're using the current PR build, then this will get fixed when current EA build goes to PR
If however you're using latest EA version, let us know to take a closer look as this should not happen anymore.
geposted Wed 27 Mar 24 @ 1:20 pm
Ah cool...i'm using 2023 b.7921. Easy enough to just go in and delete said sub folders in the parent folder in the meantime
geposted Thu 28 Mar 24 @ 4:15 pm
All set! Super easy...
geposted Thu 28 Mar 24 @ 4:36 pm
