I want to have pads 1-4 mirrored so same function and color on pad 5-8.
Execpt change from name on pad 1-4 to instead of name shows counting of -/+ bt as I have in my hotcues
No problem to change so its mirrored but what script in pad editor in "name" to show -/+ bt instead of ?
![](/img/402852/42347/Skärmbild 2024-03-29 134730.png)
geposted Fri 29 Mar 24 @ 12:46 pm
Change your savedLoopDisplay setting to distance, then name the top 4 buttons with something like this.
`get_saved_loop 2 'name' & param_equal "" ? get_text 'LOOP 2' : get_saved_loop 2 'name'`
geposted Fri 29 Mar 24 @ 2:16 pm
