How to change pad fx with pioneer hardware
can you add any pad fx to any pad slot?
i didint find any solution?
VDJ has vinly break effect?
and can u add it play button or to pad slot?
geposted Fri 29 Mar 24 @ 2:00 pm
To change pad effects, you need to edit the pads of the PADFX page.
Yes, VirtualDJ has a brake effect, and it also has a brake/ramp function for play/pause button in settings if you wish to use that as well.
geposted Fri 29 Mar 24 @ 2:02 pm
