Hi I keep
getting the reduce stem warning, I have M2 Max Mac Book Pro 2023 laptop. Is there a way I can fix this.
![](/img/402859/5809/Screenshot 2024-03-29 at 10.44.15 AM.png)
![](/img/402860/17486/Screenshot 2024-03-29 at 10.43.52 AM.png)
geposted Fri 29 Mar 24 @ 2:46 pm
How is your option "don't use GPU"?
geposted Fri 29 Mar 24 @ 4:45 pm
If you copied over with a time machine backup it won't work. You need a fresh install
geposted Fri 29 Mar 24 @ 7:43 pm
