Hello I just purchased the Rane One and I love it. Definitely a huge difference from having a 4 channel Pioneer DDJ SX2. Slight learning curve but love the spinning platters. Anyway, I was trying to map out a way to control the Sampler main volume but don't see any options. I YouTube'd this issue and only found ways to do it with Serato (By the way, sound quality on Serato for scratching is 👎). Anyways, if anyone has figured it out can you please share? Thank you!
geposted Sat 30 Mar 24 @ 6:51 pm
map your chosen bit of hardware to
sampler_volume_master
geposted Sat 30 Mar 24 @ 6:58 pm
