Hi guys,
today i upgraded VDJ to 2024 b8055, and tried to connect the new clouddrive function to my gmail drive account (dual factor access control is disabled).
After the confirmation, google blocked tha access with this: RED TRIANGLE... This App is blocked.....to protect your account, Google blocked the access...
This is the original italian text:
"Questa app è bloccata
Questa app ha cercato di accedere a informazioni sensibili nel tuo Account Google. Per proteggere il tuo account, Google ha bloccato l'accesso."
Any suggest?
Any suggest?
geposted Tue 02 Apr 24 @ 7:14 pm
Same here, APP blocked by google
geposted Tue 02 Apr 24 @ 7:47 pm
Same for me.
geposted Tue 02 Apr 24 @ 8:29 pm
I was able to sign in initially and link my account. It also has not stopped the in progress sync (continuing to take up more and more storage on Google Drive as hidden data). However, it now fails when virtual DJ prompts me to sign in, saying google has blocked the app.
geposted Wed 03 Apr 24 @ 1:41 am
same
geposted Wed 03 Apr 24 @ 7:46 am
Should be fixed now.
geposted Wed 03 Apr 24 @ 8:13 am
I'm still getting the same thing. Just tried it less than 10 mins ago
geposted Wed 03 Apr 24 @ 8:12 pm
Hello same here, first it worked then "application is blocked" and cloud is not working anymore :/
geposted Wed 03 Apr 24 @ 9:22 pm
I am having the same issue.
geposted Wed 03 Apr 24 @ 10:29 pm
How/where can we tell Google not to block clouddrive? I tried to fix it in my google account or chrome security settings but it won't help :/
Here's the error message I get each time I try to activate google drive from VDJ.
geposted Thu 04 Apr 24 @ 11:32 am
just to confirm, when you see this block from google, do you have "show all GoogleDrive folders" enabled in the context menu for CloudDrive ?
geposted Thu 04 Apr 24 @ 1:45 pm
Yes I do have that checked and recording the same error,
geposted Thu 04 Apr 24 @ 2:15 pm
RCBAudio wrote :
so that's why.Yes I do have that checked and recording the same error,
Google has a very long and slow security validation process, so in order to allow VirtualDJ to access the full drive of users, they need several months of validation.
We didn't want to delay VirtualDJ 2024 until 2025 obviously, so we went ahead and released anyway.
It should be working fine as long as you don't select "show all GoogleDrive folders".
(it used to work to show all folders by clicking advanced and allow, but Google just informed us that they have a hard limit of 100 users that can use the advanced link, after which everyone gets blocked. nothing we can do about it, and nothing they're willing to do either)
geposted Thu 04 Apr 24 @ 2:44 pm
Indeed, you are right, thanks so much for this tip
geposted Thu 04 Apr 24 @ 2:49 pm
-So no google drive then? I just spent the day clearing out and uploading to it and now it says I am blocked.
Will there be an update that removes GOOGLE DRIVE from the options so others dont waste time?
geposted Thu 04 Apr 24 @ 3:02 pm
MuffinMunroe wrote :
Google Drive works fine with VirtualDJ.Will there be an update that removes GOOGLE DRIVE from the options so others dont waste time?
The only think that is blocked, until Google finalize their security review, is to access from VirtualDJ the other GoogleDrive folders, not the ones that were made by VirtualDJ.
The Lists you make with VirtualDJ, and the tracks you upload with VirtualDJ, all work fine.
geposted Thu 04 Apr 24 @ 3:13 pm
Yes it worked! Thank you.
geposted Thu 04 Apr 24 @ 4:29 pm
Tengo el mismo problema que los usuarios anterirores me bloquea la aplicación y no logro sincronizar con la nube. que solución actual existe?
geposted Thu 04 Apr 24 @ 6:46 pm
The VDJ team responded to me saying that you need to allow access in Google settings: https://support.google.com/accounts/topic/7188760
Despite being somewhat confusing, Google always disrupts our lives
geposted Thu 04 Apr 24 @ 7:03 pm
success
geposted Mon 08 Apr 24 @ 7:45 pm
