Hello .
There is something that has been bothering me for a long time.
I also cannot turn it off by, for example. Settings such as: KeepSortOrder, or what it should actually cause Saveplaylist NO.
It is so that the program does not save playlists when I change something on the side of the browser in the Automix on the right side, but when I just click on a stored playlist and it show these in the main browser and I am accidentally Put track or even remove the track, then the next time you open the playlist it is changed, so saved.
It is so that the program does not save playlists when I change something on the side of the browser in the Automix on the right side, but it is so if I just click on a stored playlist and I am indicated in the main browser and I am accidentally Put track or even remove the track, then the next time you open the playlist it is changed, so saved.
Why does he do this, even though I have automatically saved playlists, so that I don't change what?
Sorry for the bad translation in English.
Hope you understand it.
Greetings Dani
Greetings Dani
geposted Tue 02 Apr 24 @ 11:34 pm
