In the new version the folder of history of played music has disappeared
WHY?
where is gone?
WHY?
where is gone?
geposted Wed 03 Apr 24 @ 10:52 am
geposted Wed 03 Apr 24 @ 11:10 am
Thank you very much
sorry.....
I have panicked for a moment...
sorry.....
geposted Wed 03 Apr 24 @ 11:16 am
Don't be sorry - we should be able to read about this in the Release Notes for a major release, and this is all we got
https://virtualdj.com/forums/257603/General_Discussion/Breaking_changes_in_VirtualDJ_2024_%28and_how_to_revert_to_vdj2023_if_you_need_to%29.html
and they make no mention of the History being relocated.
geposted Thu 04 Apr 24 @ 5:26 am
kenziekkay wrote :
The history is not "relocated". it's just that the parent folder display name was changed from "Lists&Advices" to "Ideas", but nothing changed except the display name.
geposted Thu 04 Apr 24 @ 7:52 am
Question to a reader: is it only me or also with you that it is no longer possible to move a history playlist to a subfolder in the last early access version? Currently, I can only move it on the same layer.
geposted Fri 05 Apr 24 @ 12:57 pm
4 builds later, it still doesn't work for me.
Is it possible for someone to check once whether the problem is only present with me or with everyone?
I'm trying to move history playlists to a subfolder under ideas/history with the mouse.
Thank you for a quick check and feedback!
geposted Thu 18 Apr 24 @ 1:28 pm
Are you holding CTRL or SHIFT while dragging?
geposted Thu 18 Apr 24 @ 1:49 pm
Until now, this was not needed! But yes with SHIFT it works!!
Thanks for the tip!
It is also unusual that after moving the entire tree now closes!
But I can live with it!
Thank You!!!!
Thanks for the tip!
Thank You!!!!
geposted Thu 18 Apr 24 @ 1:57 pm
