Hi all,
I'm new to Virtual DJ - switched from a "competitor" software which kept crashing without warning (during gigs!)...so far so good on that front with Virtual, however...
When I move the crossfader from one deck to another this does not change which deck is cued to headphones, currently I'm having to do this manually on my controller.
Is there a way to change settings / edit mapping so the inactive deck cues to headphones when moving the crossfader? I hope so!
Any help greatly appreciated.
Gaz.
Gaz.
geposted Wed 03 Apr 24 @ 8:50 pm
setting autoheadphones
geposted Wed 03 Apr 24 @ 8:58 pm
Hi LOCODOG, this is already set to "always".
geposted Wed 03 Apr 24 @ 9:00 pm
Ok depends on your gear but you could remap your crossfader from
to
or even this
crossfader
to
crossfader & param_bigger 0.5 ? deck 1 pfl on & deck 2 pfl off : deck 1 pfl off & deck 2 pfl on
or even this
crossfader & param_bigger 0.55 ? deck 1 pfl on & deck 2 pfl off : param_bigger 0.45 ? deck 1 pfl on & deck 2 pfl on : deck 1 pfl off & deck 2 pfl on
geposted Wed 03 Apr 24 @ 9:13 pm
Brilliant, thanks very much! I bought you a cold one in appreciation.
geposted Wed 03 Apr 24 @ 9:59 pm
Noice one bruva, :)
geposted Wed 03 Apr 24 @ 11:18 pm
