If you use CloudDrive to keep your primary DJ laptop and your backup DJ laptop in sync, it would be great if there was and offline sync option, so that the backup laptop will automatically download all synced changes at home while it's still online before leaving for a gig
That way the backup will still mirror the primary laptop even if there is no wifi available at the gig
Currently tracks will by default be streamed from the cloud storage (even if the tracks are already present on the backup laptop's harddrive, because for instance dropbox has downloaded them as part of how dropbox generally works)
geposted Wed 03 Apr 24 @ 11:34 pm
+1
geposted Thu 04 Apr 24 @ 8:13 pm
yes, that's how it works.
geposted Sat 06 Apr 24 @ 2:56 pm
In earlier posts you were saying it only streams the tracks. Now you're saying it downloads?
geposted Sat 06 Apr 24 @ 3:36 pm
If you play from the Cloud Drive, it streams, if you chose to sync a cloud folder on another computer, it downloads it to the other computer.
geposted Sat 06 Apr 24 @ 3:43 pm
I believe they are trying to say that you can play from the CloudDrive without internet and it will all be in sync.
geposted Thu 11 Apr 24 @ 1:03 am
