I got a DDJ-FLX10 with out of the box mappings and I'm trying to access the 2nd page of hotcues (9-16 pads).
By default, when pressed the track instantly jumps to the next (+) or previous (-) hotcue, which is kinda weird to me, coming from rekordbox. I checked the mapping and it is set as:
pad_param +1
I tried changing it to
I stumbled onto this other post https://www.virtualdj.com/forums/257457/General_Discussion/DDJ-1000_vs_FLX-10_mapping.html with the exact same issue, but it's unclear to me what the solution was. It is mentioned to use Hotcues XT, which I installed, but the page buttons still behave the same way (jumping between already existing hotcues).
What's the correct way to map these?
pad_param +1
pad_page 1and
pad_page 2but that instead makes it jump to the "Pad FX 1" pads when I press next, and nothing happens when I press previous. I assume I'm misunderstanding what `page_page` does.
geposted Fri 05 Apr 24 @ 1:04 am
change it back to
pad_param +1
pad_param +1
PhantomDeejay wrote :
After downloading and installing the page, you can even rename it to "hotcues" instead of "hotcues XT" making it your "default" hotcues pad page for any controller you use...
geposted Fri 05 Apr 24 @ 3:56 am
It is currently set as pad_param +1, and it retains the same original behaviour (jumping between existing hotcues).
How would I rename it? I'm not exactly sure where the extension is found.
geposted Fri 05 Apr 24 @ 1:01 pm
open settings, in the bottom right corner is a gear icon, click it
the folder that opens will have a sub folder called \pads
that's where pads are stored.
geposted Fri 05 Apr 24 @ 1:17 pm
If you use the addon (Hotcues XL) then:
1) The preferred way is to assign "HOTCUES XL" as your hotcues pad page.
See the manual on how to do this:
https://www.virtualdj.com/manuals/virtualdj/interface/decks/decksadvanced/pads/index.html#controller
2) If you wish to SUBSTITUTE the normal hotcues page with "hotcues xl" globally, then:
Open settings.
Click options.
Click the cog on the bottom right corner of the settings window.
Exporer/Finder should open in VirtualDJ home folder
Close VirtualDJ
On the explorer/finder window that opened up before, open "pads" subfolder
Rename "hotcues xl.xml" to "hotcues.xml"
Start VirtualDJ again.
While there's no problem, or risk on substituting hotcues page with hotcues xl, it is not advised to do so.
You can have both pages on your system, and you can easily assign "hotcues xl" on the places you want it to take over.
PS: "Hotcues XL" works with factory default mapping of any controller. You don't need/have to remap any buttons for it to work.
Open settings.
Click options.
Close VirtualDJ
geposted Fri 05 Apr 24 @ 1:35 pm
Thanks. I think that got me closer to understanding how this works.
Now I seem to be able to reach the 2nd page with Hotcues XT, excellent! However, I'm still wondering why is this not possible with the default hotcues, or rather, if there's a way to change it through the Pads Editor or if there's some button I'm not pressing.
In the pads editor I see that Param 1 is set to goto while Param 2 has goto_cue. By reading the description I see that this is the behaviour I've been experiencing.
Is there something I can use to set it to pads 1-8 for Param 1 and pads 9-16 for Param 2?
geposted Fri 05 Apr 24 @ 2:35 pm
