Hello, What are these two icon's that show up on several screens while using virtual DJ they seem to do nothing but get in the way when trying to select settings in several screens. Can I turn them off?
geposted Fri 05 Apr 24 @ 10:54 am
They are not from VirtualDJ
Most likely they are from you Graphics driver, or another utility that runs on your computer.
Check your tray for any application running there, and try to kill them one by one, until you find which one is responsible for these icons.
geposted Fri 05 Apr 24 @ 11:22 am
Thank you and you were correct. They were showing up on other software I was running. It was part of the Nvidia driver. I had to open the Gforce experience - Settings - and turn off ingame overlay, closed VDJ and they were gone.
geposted Mon 08 Apr 24 @ 1:13 am
