Using Build 8056, When I create a filter folder under a virtual folder, every time I collapse and expand said virtual folder I get "Error Creating Filter Folder" in the Browser Pane. Also any attempt to delete it from within VirtualDJ is unsuccessful. I have to go into the VirtualDJ folder itself on my computer to delete the "file" to make it go away.
geposted Sat 06 Apr 24 @ 10:17 pm
I can create it within the Ideas/Filters menu and move it. However when moving, it immediately disappears when dropping it into the new folder until VDJ is restarted.
geposted Sat 06 Apr 24 @ 10:20 pm
I reported this message a while ago, and also recently bumped it. I'm not aware of any response from Atomix.
geposted Sat 06 Apr 24 @ 10:43 pm
I have upgraded to 8091 EA.
I can now create the filter folder, and it will allow me to rename it. However as soon as you finish setting it up, it vanishes until you restart VDJ.
geposted Mon 08 Apr 24 @ 11:34 pm
indeed, it's been fixed for next build, thank you for reporting it.
geposted Tue 09 Apr 24 @ 8:43 am
