In my case, when I try to prepare with stem2.0, for some reason it becomes stem1.0 when separated, and the quality deteriorates. Is there a way to force separation with stem2.0? If my laptop is not capable enough, please recommend a Windows laptop. Surface is better if possible.
geposted Sun 07 Apr 24 @ 12:50 am
What is the graphics card of your computer ?
Requirements for Stems 2.0 is listed here.. https://www.virtualdj.com/wiki/Minimum%20system%20requirements.html
geposted Sun 07 Apr 24 @ 8:21 am
Thank you for your reply. When I checked the GPU, it was Intel(R) HD Graphics Family. I have some songs that were converted using Stem 2.0, but I can't reproduce them. Is it because the specs are insufficient?
geposted Sun 07 Apr 24 @ 10:02 am
geposted Sun 07 Apr 24 @ 11:33 am
Check options and see if 'Prepare with reduced quality' is enabled for the stemsFix option
geposted Sun 07 Apr 24 @ 11:52 am
stemsfx already had Prepare with reduced quality enabled
geposted Sun 07 Apr 24 @ 12:31 pm
geposted Sun 07 Apr 24 @ 12:32 pm
Yes, only reduced quality (Stems 1.0) for this computer
geposted Sun 07 Apr 24 @ 12:48 pm
It needs to be disabled to prepare stems in full quality
geposted Sun 07 Apr 24 @ 12:53 pm
oh God,
Please tell me a Surface that can fully utilize stem2.0. It doesn't have to be possible to separate in real time. I prepare stem2.0 before playing.
geposted Sun 07 Apr 24 @ 1:56 pm
When I disabled it, a pop-up appeared saying that the stem system was in error.
geposted Sun 07 Apr 24 @ 2:02 pm
Try to select 'Don't use GPU' as well
geposted Sun 07 Apr 24 @ 2:46 pm
